JamesO
I currently have a bit of a dilemma. The 968 engine in my lux was cheap because the exhaust cam is missing one tooth so I have been running a s2 head and cams. Annoyingly I discovered when changing a sticky tappet that the cam saddles and both cams have become scored very badly (they were definitely fitted in the correct order and way round).
I have removed the head and taken it to the machine shop to see if it can be saved, in the meantime I have decided to fit the 2.7 head off the old engine while I decide what to do.
As I see it my options are as follows:-
1. New 968 cam, very expensive and should be done in pairs.
2. Have the 968 cams repaired by RS Barn $650 plus shipping twice, import duty? and a long wait.
3. Stick with the s2 head depending on the report from the machine shop.
And the slightly daft option but most interesting
4. Take advantage of the lower compression ratio with the 8 valve head and go for a lowish boost turbo.
Lurking in my garage I have a turbo inlet, throttle body, intercooler and intercooler pipes so would still need a fair few bits.
Any opinions?
Any opinions?
