chrisg
Hey Peanut, Apologies if you're aware of this already but, the profile number 45, 50, etc is a percentage of the width. So for your tyres: 225/ 45 = 45% of 225 = 101.25 255/40 = 40% of 255 = 102 So, although these are an exact match you end up with tyres that give or take a couple of mm (subject obviously to wear) are the same diameter and don't affect the gearing of the car. Having said that though, my 951 runs as standard on 16" with: 225/50 = 50% of 225 = 112.5 245/45 = 45% of = 110.25 So in effect by my reckoning the total diameter of your wheel/tyre combination is larger than the standard turbo/ s2 which has an effect on both top speed and acceleration - I can't remember which way round this is though, I'm sure someone will correct me !
