Cab cills
- Thread starter 944Turbo
peanut
if you do, take care with levering out the plastic grilles. They are held in with two clips one top one bottom which are very brittle .Once broken you'll have to replace or stick the grilles in with silicon or whatever .
The best way to view and treat your cills is to remove your seats and pull back the carpet strips on the internal cills . Underneath are some large rubber bungs along the inner cill which can be removed for easy access along the entire cills.
