This has got me thinking as I recently wrote on a post 'you can gain 40 hp relatively cheaply on a turbo' but on reflection I don't think this is true. So I thought I would pose the question for those thinking about this of the best way it can be done.
When writing the comment I was thinking cheap chip off ebay that has the boost protection removed plus a manual boost controller equals 40 hp for around 200 quid. Whilst this may be true if you drive the car hard for prolonged period you will more than likely burn out a valve (I did) as it is running to lean at higher boosts costing thousands to repair. So then you have to go down the remap route but to get this working probably you need new injectors, 3 bar fpr, and boost controller just to gain the 40 hp safely but at a cost of 1000 pound plus a remap cost every time you make a further change.
So finally I have come to the conclusion that there is no such thing as cheap and if you are going to upgrade you need to bite the bullet and upgrade the turbo, injectors, 3 bar fpr, dpw, 3" exhaust, fit a maf, upgrade ecu, fit an ebc, bigger intercooler, widefire head gasket to gain 70 - 100 hp! And if your doing all that then tackle the bottom end at the same time...
