Morning All, Having some clutch oddness with my S2.
Measured the wear and it's about 50% worn at 140k (easy life until I got it), but for a wee while it's juddered a bit going from 3rd to 2nd unless revs are matched.
For a couple of weeks the bite point has been quite high in the pedal and quite sudden. Then last weekend the first half of the travel in the pedal went very very light, as if it's not moving anything and the bite point is right at the bottom. Gears are engaging absolutely fine with no slippage but something clearly amiss?
Slave & Master Cylinder? Release bearing? or am I destined to spend this year doing a clutch change I can ill afford at the moment.
