Engine Removal
- Thread starter Guest
Peter Empson
The engine can come out of the top or the bottom, but I believe the easiest way for most people would be from underneath.
best regards,
Peter
Use the engine hoist to lift the front of the car high enough to give you clearance to drop the engine down, or, drop the engine and then raise the car higher afterwards.
Oh, and dropping the cross member, for the sake of undoing four bolts, drop the steering rack from the cross-member - it is a lot lighter to remove the two components seperately, and a lot easier to reconeect to the steering shft with the rack loose.
Tref.
How-ever, I know that I ended up lifting the car off the jack-stands once when liftying the engine back in., so I guess you could lift the car by using the engine lifting points. how-ever, concern over engine mounts would mean that I would prefer to rope around the two front chassis rails.
Thats how I did mine.
Mike
Diver944
ORIGINAL: os951
I usually take these pictures, so i can be anonymous []
That's always the best way [
Mike
Mike
Edit - sorry - getting confused having barbie - may nee to remove both inner mounts of wishbone and use engine hoist to lift front of car and slide engine out under the bumper.
