Jump Starting a 992 GTS
ralphmusic
The Hybrid 400v battery is used to start the engine and can only be charged during normal road use (recuperation etc) or by a Porsche Centre using special equipment. What happens if it becomes depleted and has insufficient charge to start the engine, can the engine be started using a booster or with jump leads?
No, not as far as I am aware.
At a recent launch in Reading, we were informed the main drive battery augments the slave battery and will come into operation should the starter voltage become too low. Jump starting is not needed nor indeed possible. šŸ¤”
Regards,
Clive
Clive,
This was posted on pff.de in the "992.2.- Wann commit das Facelift?" thread.
The last (partially obscured) line reads as follows:
"The interaction of E-Boost and recuperation takes place automatically in each driving mode. It cannot be actively influenced."
I don't know whether this chimes with your info from the launch but it seems to have a couple of maintenance wrinkles.
The speculation on the 992.2 GT3RS is that it will use the same hybrid technology since the 992.1 version has maxed aero at the cost of outright speed and needs more HP to compete with Mercs and Ferrari performance in showroom stats and GT3 category racing.
