Vic Rattlehead
Hi all.
Recently fitted a VDO mechanical boost gauge. WOT in 3rd 4th and 5th is showing 12psi.
Now, I was thinking I'd be seeing more along the lines of 15psi, with the modifications on the car.
Lyndsey boost enhancer, 3bar fpr, promax chips and baily blow off valve. This was already fitted when I bought the car two years ago and it looks like the previous owner wound out the boost enhancer to nearly it's maximum, as according to rennlist they say the factory 10psi setting is about 4 visible threads.
So anyway, I've just done the wastegate test and clamped off the line from the intercooler hard line (as acceptable as clamping off the line from the cycling valve acording to rennlist) and got the same results, which is leading be to believe the wastegate is dead.
I was wondering if anyone here had done the wastegate test clamping the line from the hard pipe. Or is it not as reliable as clamping the line from the CV
Also, the VDO gauge isn't wired into a switched 12v yet, I'm assuming as it's a mechanical gauge it wouldn't need power to work correctly?
Cheers in advance.
Cheers in advance.
