No Charging Volts
barks944
So my car is running on battery volts only, there is no change in voltage when the engine goes from running to stopped and the battery eventually goes flat. Is there anything except the alternator that could cause this. I do have an untested one but I fitted it an it made no difference, this obviously doesn't say much as I have no idea if it worked in the first place.
Not a lot of choice!
Alternator have brushes, most of which come out of the unit with the rectifier, its worth checking those, as the bit is a lot cheaper than the alternator.
Mike
When the engine is running if you put a multi-tester across the battery terminals it should be reading about 14v. If it is reading 12v or less then the battery is not charging and therefore is something to do with the charging side.
Early cars certainly dont have a fuse in the charging circuit, not sure about Turbos
Is the tacho working? I thimk it needs to sense a minimum revs before charging, but otherwise there is not much to the charging bits.
Mike
Just been checking the wiring diagrams for this. It appears there isn't a charging fuse. You don't need to put a meter on the battery mate. That's the beauty of a car with a proper voltmeter in the dash. If it is reading 12V and no more when running then dropping then I would suspect the alternator or anything inbetween i.e. wiring. In my experience probably the rectifier in the alternator but it's all internal.
Rectifier is in unit with the brushes - at least on the 2 (different) ones I've played with. I did find the spares I wanted were still listed but in the end I didn't need them.
Mike
Brushes???? It is a 3 phase AC generator isn't it? With a diode rectifier to rectify the output to DC. Why would it have brushes?
Don't know - but my original and the one on my replacement engine (oval dash) both have brushesmounted on a plate retained by one screw.
Mike
edit The plate has diodes (I assumed) and as the brushes had almost worn out on one I swapped them as the older alternator wouldn't fit the later engine - belts didn't line up
Just had a look on PET mate and can't find any mention of brushes. They are usually only used on DC machines i.e. DC motors or to supply DC field current to AC alternators.
I'll have a look at my spare tomorrow - if its not got them I wonder what kit I'm thinking of? Lawn mower ot something!
Mike
Its definately not charging and the car is a 1984 lux not the turbo mentioned in my sig. The brushes are on the voltage rectifier/regulator unit that is attached to the back of the alternator. I guess the current is generated in the rotor which is why the rectifier has brushes to connect it to the spinning rotor.
I can't get at my shelves to check mine -lots stuff in the way and bad back!- but if I remember correctly brushes start about 20+mm long but 1 of mine was down to 3-4mm and I was getting very low volts- 6 or 7 IRC.
Mike
Sounds as though it's all part of the rectifier assembly. I imagine the recifier can only be purchased as a complete part. In my experience it is generally the rectifiers that go. They are only diodes after all. As long as the alternator windings haven't 'Birds Nested' they should probably be ok. I would seriously try and get a rectifier.
My dad took the original and spare into a small alternator rebuilding shop and apparently the spare just had a dirty slip ring. Just testing the original now....
Alternators do not have brushes.
They do have a slip ring.
Many people think the slip ring ( carbon stick on a spring running on a rotaing contact) is a brush - it is but it does not run across a segmented commutator which wears brushes down so has a much longer life.
If the slip rings carbon brush is dead or the rotating contact is badly worn that could cause problems but rectifiers - diodes are much more likely
ORIGINAL: vince944red
Thankyou mate a I was trying to explain last night alternators that are not self excited have to be supplied with DC field current. This is usually achieved by means of a brush and a slip ring and not a commutator as you just explained. The brush will wear though as electron flow will will transfer carbon from the brush to lubricate the slip ring. I do agree though that this is far less than a brush running against a segmented commutator.
Wasn't sure what the sprung carbon rods were acting on, but they look like brushes! (and at least my memory is ok!)
Had a look at exploded view and understand how they work - its good to learn!
Mike
PS - glad problem is being solved
