radiator
- Thread starter Alpine
Mike
morris944s2john
I'm not sure if it is possible to recore plastic/ aluminium radiators.
Edit - original thread is here http://www.porscheclubgbforum.com/tm.asp?m=513753&mpage=1&key=񽛙
Northern924
If you're doing it yourself a couple of hours should cover it, just remeber to do it on a cold engine [
pauljmcnulty
£300 new, £160 recored. Fitting, fluids etc. probably as much as the difference. I'd do it once, swallow the £140 and sleep comfortably knowing it was sorted for the next 20 years. [8|]
