Northern924
I've been running the '44 on a set of 993 cup2's, but the rear has a 9" rears with a 70 offset, there's clearence on the inside, but I'm wanting to get them level with the fronts which are 7" with a 55 offset, which IIRC is very close to the correct offset.
Am I right in in thinking that 15mm spacer will level things up. IF thats the case can the standard studs cope with a 15mm spacers or will I need to fit longer ones?
And if thats the case.... who has a set of wheels with the correct offset for a 1988 '44 that need a light refurb but have good tyres and wants to swap for the set I have in same state [
