Sunroof won't go up, only down - SORTED
- Thread starter zcacogp
Eiger
I've checked the microswitch in the roof and obviously the mechanism works because it retracts correctly. I've tried adjusting the depth of the "adjusting screw" but to no avail.
I'd really like my sunroof back! Any ideas?
Helen Goff
No.1 Poster
Eiger
Oli I checked this mircoswitch by manually raising the roof (with the roof out) then holding down the microswitch by hand then ignition on and "closing" the roof. So the retracting mechanism is working with the microswitch depressed even by hand. Barks I'll see if I can remove the switch and short it as you suggest. If there's one thing I don't get is electrics... Helen - I thought that because it raises manually and closes by pushing the button that the cogs may be ok. Failing Barks suggestion, I'll take a look at those just to eliminate them. What I can't understand is why the motor whirs away but doesn't lift the roof, but it will retract it...ORIGINAL: zcacogp I had the same symptoms with my sunroof and it was the microswitch in the roof. You say you checked it ... how? (One diagnostic would be to push the microswitch in with a pencil or small screwdriver while pressing the "Roof Up" button; does it solve the problem?) Oli.
pauljmcnulty
One of the limit switches on the motor might be loose, fooling it into thinking it's fully lifted when it's not? I don't get electrics either, but it's more likely than the cogs if it's working one way.What I can't understand is why the motor whirs away but doesn't lift the roof, but it will retract it...
Bit more detail required ... and we'll try to help you! [ORIGINAL: Eiger I have read and re-read Clark's guide, but I must admit I'm not sure how the tightening procedure works. I'm no good with electrics and Clark's suggest some electrical procedure. I've tried again adjusting the screw to different depths but still just whirring....
Northern924
Eiger
Whirring like the motors just spinning - which now it's not doing anymore...since I tightened the lock nut - it was doing it when I should have been opening the roof. The roof closes correctly if I manually put it up by turning the bolt/screw in the motorORIGINAL: zcacogp What sort of whirring do you get? And when? Does the roof open at all? Or close at all?
do you mean the lock nut on the adjusting screw?ORIGINAL: zcacogp If it is a matter of the clutch slipping then you need to do the (13mm, IIRC) nut in the centre of it up a little. But be careful not to over-tighten it otherwise you will strip the gearwheels when you next retract the support arms. Oli.
Eiger
