vince944red
Been trying to adjust tickover as it became too low but not much scucess after following instructions
Short out pins b and C on diagnostic plug to deactivate Idele control valve - done
Adjust tickover to around 850 - done
but then the fun starts, (I definitly got the right pins shorted as tickover speed dropped)
when I adjust the screw to give 850 rpm with ICV off as soon as the shorting wire is pulled the tickover jumps up to 950
Am I doing something wrong here or is there somenthing wrong with the ICV?
In the end I had to adjust it with the ICV on which contradicts the entire procedure!
