Peter Empson
I have the SciVision MAF on my car, I think that www.deutschnine.com sell the latest version of this. I'd combine it with one of the Promax chip unless you want to get someone like Chipwizards to do a proper rolling road remap (which will be quite a lot more costly, and best only considered once you've done all the likely mods you might want to).
I'd also suggest looking at www.vitesseracing.com who will do a MAF for you and I'm sure can provide a chip to suit, it will probably be a bit more expensive but it's a more advanced solution and the after sales is second to none in my experience.
Installation is pretty straight forward (I think the Scivision is a little simpler 'plug and play' than the Vitesse), definately possible to DIY quite easily, or get a garage to spend an hour or so doing it for you.
You will get much better throttle response from the MAF, so the car will feel much more responsive and the chip will bring better part throttle reactions (much nicer to drive) and I'd expect an improved torque curve too. In terms of perceived improvements I'd expect it to knock years off the way the car drives.
