scam75
Well-known member
Hi Guys
So the car is nearly there and back together. Neither front fog is coming on, and the OS front indicator is not coming on. All were working before. Main and dipped beam is working properly.
I suspect the actual unit for the front indicator may need replaced as it was always ropy before. I had given it a good clean up so that may i have killed the unit totally....
The rear fogs are coming on and both switches illuminate as usual in the dash, rear fogs won't operate unless the fronts are on but I'm sure that is normal and the way it was before.
All fuses seem good. Haven't checked the bulbs but with both being out it would seem odd that is was the bulbs.
Any ideas?
Stuart
Any ideas?
Stuart
