ORIGINAL: DivineE
ORIGINAL: Tam Lin Last year being driven round Silverstone in a 944TurboS with diff, I was amazed at some of the oversteer angles that were still recoverable, which I certainly wouldn't have been able to do in mine. But then, that was probably 99% driver ability and 1% diff...
Yes I found the opposite to be true with the open diff turbo I had. The back wheels felt totally inpedendant and it would only get to a certain angle even with full throttle, then after a few second you felt all the power being lost and transferred to the inside wheel, the back end would actually come back a bit. In a LSD equipped car the back end moves as one lump behind you, you get much stronger drive but if you keep your foot on the throttle without backing off when it starts to slip it will never get to that point, it just pendulums out and spins you.
