peanut
ORIGINAL: James Ball
A separate and unrelated question - my car runs lumpily on part throttle around 2000 rpm, almost as if were on out of tune carbs. Any obvious culprits?
Might be worth doing a thorough check of all your vacumn pipes and connectors for a split or hole . Maybe pull them apart to check and re-connect. Sounds like maybe a leak somewhere in the inlet
Various ways you can test in-situ. You can spray with propane gas or carb cleaner apparently ! sooner you than me lol
