0-60 time
- Thread starter Guest
ORIGINAL: amolak
Hi,
Is it true that the 3.2 has a quicker 0-60 time than the 964 c2/c4?
Amo
No. Well, certainly not than a C2 (about 0.5 s. slower, in fact). The off-road version* may be a bit slower, though.
*964 joke[
I depends which tests you read. I have seen as low as 5.3 in some road tests - which is as quick as any 964 C2 tests I have seen.
Don' t want to burst your bubble Bluebottle but a 3.2 has a pretty good power to weight ratio. If memory serves correctly, we are talking 231hp to move 1210kg (book weight), whereas a C2 has 250hp to move quiet a lot more weight - 1450kg (or is that the off-road version[
Feel free to correct me if my guesstimates on weight are way off.
Richard
My wife`s 90 964 C2 is a lot quicker than my 89 3.2
Have you checked that you are getting full throttle on the 3.2? When I bought mine it was getting less than 3/4 throttle. Apparently this is very common. Surprisingly, this made perhaps less difference than you might expect. At high rpms it was " ok" but in the midrange, in high gears especially, it was completely lacking in torque. A quick adjustment to the linkage under the accelerator and all was well. Worth checking anyway.
BTW, if by " sports box" you mean the cup bypass pipe mod that many 964s have, then it does make a difference.
I have driven 3.2s and 964s and I am hard pressed to pick with " the seat of my pants" any real difference at sensible speeds - perhaps my butt isn' t sensitive enough. I suspect that a drag race is what is called for. Any volunteers.
R
