16' Boxster Wheels
- Thread starter berg944
There is a good link in the General FAQ that explains a lot about wheels and how to make sure they will fit.
Weird. I thought teledials had them - almost all Porsche Wheels do...
They should be on the outside. Any 944 owners care to hazard a guess?
If I recall correctly, it depends on the 944 and how it was specced whether the wheels are bigger at the back - some were. The 16" Boxster wheels certainly are different (6" wide at the front, 7" wide at the back). I haven't got the offsets handy though (sorry).
Diver944
The manual for an '86 car should have the correct sizes in the back but this website http://members.rennlist.org/951_racerx/ lists that standard for an '86 car they should be 15" x 7" with an offset of 23.3 mm front and rear
Then use this excellent website http://toy4two.home.mindspring.com/offset.html to put in the size and offset of the Boxster wheels and it will tell you what size spacer you need. Bear in mind that good quality spacers of around the 25mm mark will cost over £200 for a set of four []
ORIGINAL: Diver944
Unfortunately they didn't start putting the size and offset by the valve until the Design 90 wheels came out []
Whoops! Sorry about that Mike - the memory must be going! (I had teledials on my 1st 944 - a Lux. I was sure I remembered the sizes being shown!)
Thanks Paul for the correction[]
