16" rears 15" fronts
- Thread starter ever88
Diver944
The offset determines how far from the hub the wheel will sit so it will make the back sit 29mm inside the wheel arch compared with the fronts [&:]
ORIGINAL: Diver944
No it's not normal, the pre '87 cars were supplied with 15" wheels all round with a 23mm offset and the post '87 cars had 16" all round with a 52mm offset.
All lux models & the S had 7x15" all round as standard right up to '89 (16" optional).
All S2 & 220 turbos had 7x16" fronts, 8x16" rears. Wider 16" rims were optional, later 250 turbos also had wider rims (depending on year).
Legally you're okay having different diameters front & rear as long as the larger wheels are at the back.
