Does anyone know for sure what 17" rims fit straight on to an S2 Cab, will 964/993 wheels go straight on or are the offsets different, come to that, does anyone know what the offsets should be for 17's only you often see cup 1's and 3 piece split rims for sale but with front tyre sizes for a 911 and wondered if they are the same rims, Ta!, Andy.
17" WHEELS.
- Thread starter AndyRR
Not sure of the wheel sizes but you will also have to change the front castor mounts to the later style ones as fitted to the 968 if you want to fit larger than 16" wheels to a 944.
This is a Porsche recommendation.
Cheers, Tim.
P.S. apparently it's not too expensive or difficult to do yourself.
Cheers, Tim.
Except that you need to have the suspension alignment checked and re-set afterwards.
Many of us have been running 17" wheels on the old caster mounts without problems. The 968 caster mounts have less rubber and, apparently, help to reduce tramlining which can become more apparent with 17" rims.
The main change isn't the rim diameter, as the lower profile tyres mean the overal diameter remains the same, it is through an increase in width.
edited to take out some of the spelling mistakes
Over here "acrossed the pond", I have seen 3 separate cases of the original caster blocks failing on 944 cars after owners have upgraded to 17" wheels. By "failing", I mean that the rubber center has been torn out and there is a large amount of play/movement. Nothing catastophic, but bothersome, none-the-less.
Regards,
Jeremy
Regards,
Jeremy
Diver944
These are the offsets that fit the ABS equipped cars like your S2:
Front
7" with offset ET55 and 205/50 ZR17 tyres
7.5" with offset ET65 and 225/45 ZR17 tyres
Rear
8.5" with offset ET50 and 255/40 ZR17 tyres
9" with offset ET55 and 255/40 ZR17 tyres
See the alloys section of David Sims excellent website for full info on the new mount and castor setting www.944turbo.org.uk
Front
Rear
From http://www.wheelweights.net:
Porsche 968 17" wheels (presumably cup 1) 20lb front / 23lb rear
Porsche 993 17" wheels (presumably cup 2) 18lb front / 19.5lb rear
Mille Miglia 17" Cup 2 replicas 24lb front / 26lb rear
So comparing like with like (cup 2) they appear to be about 3kg heavier per corner. As Tony states, unsprung weight has a much larger effect than sprung weight - I read somewhere that as a rule of thumb, a pound of unsprung weight saved is worth four pounds of sprung weight.
NorthernBloke
Andy
I don't want to hijack your thread but wondered if anyone could tell me the sizes of the standard turbo wheels, ET tyres etc as I'm thinking of getting some for my S2
Andy
Andy
