18" Wheels Again
Steve Humphreys
I have been looking at some 18" wheels to use as track wheels and the part numbers, I am told are 993.362.134.05 - 7.5 X 18 front and 993.362.140.01A ET65 - 10 X 18 rear--I wasn't given the offsets for the front
Will these wheels fit on a widebodies Carrera S and what car are they likely to have come off--are they boxter wheels?
My current wheels are the hollow spoke 18" wheels 993.362.140.00 10JX18 and 993.362.136.00 8JX18 with the offsets ET 40 rear and ET 52 front--these wheels do not match any of the specs in Maurice's FAQ.
Many thanks for your help.
Steve
Your current hollow spokes are the correct size and offset front and rear and you should get the same sizes for your track set.
The ones you are looking at are narrowbody rather then widebody (ET65 vs ET40) and probably off a early 996 or a mix of 996/Boxster hence the 7.5 fronts (which are too small really).
Ian.
