18'' Wheels Boxster
- Thread starter Guest
At least you can put 18" wheels on your car - they are only permitted from 1998 Model Year onwards - some modifications were needed to the chassis to accomodate the harsher battering it gets with lower tyre sidewalls. These mods were only done from Model year 1998 onwards.
Tyres... What are you looking for? Comfort? Long life? Ultimate grip?
Carl.Young
Ivor
I have 18" Carreras on my 03 Boxster and love both the looks and the grip that they provide. The ride is definitely firm on some minor roads (the poorly maintained ones with lots of ridges below the surface dressing) so I just keep the speed down. My experience with smaller sizes is limited to the test drives I took when choosing the specification of the car. I was concerned that the ride on 18" wheels would be too harsh so drove a number of different cars with alternative wheels and was pleasantly surprised by the 18"s.
I can only comment on the tyres fitted as original equipment - Michelin Pilot Sports. I have been happy with grip, wet weather performance and wear rate, including the handling and grip on a track day. Road noise is not a problem either.
Good luck in your choice. Make sure they're N rated!
The biggest problem was the car just didnt handle as well, my wheels are shod with Dunlop SP9090 tyres.
I had my local OPC laser align the suspension to suit the new bigger wheels. When I collected the car its was a different beast, handling was better than the 17" wheels, Tyre noise was no louder.
Hope this helps
Most speedo's over read. There seems to be a 3mph "error" built into the Boxster speedo. I have 17" wheels and the speedo reads 3mph more than the Road Angel. The Volvo is out by 10%, i.e. 3mph at an indicated 30mph and a somewhat excessive "error" of 7mph at an indicated 70mph!
Andrew
Ivor
http://p-car.com/technical/tires.htm
Personally, I would not fit tyres that are not N rated. If Porsche has gone to the trouble to check out the suitability and safety of a tyre, it is sensible to make use of that expertise.
Is it a different tyre? Surely it's the same tyre, tread, rubber etc that porsche has tested. They haven't after all tested the individual tyre that you fit new to your car even if you buy it from a P garage.
Is there any difference in the MPS N from a P garage and a MPS that is not?
I'm not trying to be difficult I just don't understand.
Thanks for bearing with me!
But, subjectively, I prefer the slightly smaller options. 17" for the 986 and 18" for the 987. The motoring press say the 997 is nicer on 18"s rather than 19"s and the same is true of the BMW E46 M3. The extra rubber should provide more compliance, less road noise and more progressive handling. And, the smaller wheels are also, usually, a bit lighter and less prone to kerb damage.
Of course, the brand of tyre can also make a difference. There is some suggestion that Pirellis (particularly Rossos) are better than Michelins, albeit with slightly higher wear rates.
Incidentally, Caterhams can be specified with wheel sizes from 13" to 16", but all the fastest and most powerful cars (R400, R500. Superlight R etc) run on the 13" wheels.
If Costco (or any other tyre dealer, such as Elite, Micheldever, even Kwick-Fit) can supply the N-rated tyre then no - there is no difference to the ones supplied from Porsche (they get them from a distributor as well).
But do not get the non- N-rated tyre instead. The N-rated tyre IS designed in conjunction with Porsche, and IS different.
Hope that helps...
