Great! Here’s a tailored version of your post specifically for Rennlist or PistonHeads—more technical and Porsche-owner focused, but still clear and approachable:
Subject: 2015 Panamera Diesel - Limp Mode After Kickdown (Fault Code 0603)
Hi all,
Hoping someone can help shed some light on an issue I’m experiencing with my 2015 Panamera Diesel (970 model).
The car drives perfectly under normal conditions, but if I use kickdown to accelerate hard, it immediately goes into limp mode, and I get a “Take vehicle to workshop” warning on the dash. If I turn the ignition off and back on, the message disappears and the car drives normally again—until the next hard acceleration.
I scanned the car using my iCarsoft diagnostic tool and got the following codes:
From what I understand, 0603 relates to the electric energy management (eEm) system. The battery is brand new, and I’m not experiencing any other obvious electrical issues. The fact that it only happens during full throttle makes me wonder if it’s a voltage drop or some kind of electrical load protection triggering limp mode.
Has anyone experienced something similar? Could this be caused by:
Appreciate any insight or suggestions. Happy to run further diagnostics if needed.
Best regards,
Steve Baker
Let me know if you're posting this on Rennlist, PistonHeads, or both—I can tweak the tone slightly depending on the platform. Want me to draft a quick title and post for Reddit too?
Hi all,
- 0603 Passive / Sporadic Consumer Shutoff (eEm)
- 8144 Passive / Sporadic Communication with Air Quality Sensor (LIN bus vehicle)
- A weak alternator?
- Poor ground or power connection under load?
- Air quality sensor interfering via the LIN bus?
- Or possibly a software/ECU glitch?
Best regards,
Steve Baker
