2015MY Cayenne S Diesel - leaking washer system
oldnickers
I've had my Cayenne S Diesel since mid-2015 - bought as an ex-Porsche GB car with under 2000 miles. Since the first week the washer bottle has not retained water when brimmed, usually losing around 3 litres without any use of the washer system.
Dealer has been fantastic - they've had the bumper off numerous times, changed the headlamp washers, swapped the complete system with a demonstrator vehicle, raised the filler neck, all to no avail. In fact they've now identified that all their Cayennes appear to have the same problem. Aside from it being just plainly wrong, I don't like the smell of washer fluid penetrating the cabin. Apparently the escaping water collects in a chassis low point and then, when full, it starts leaking to ground. It appears in the wheel arch liner and at the rear of the bumper - and it's not immediately obvious since the chassis needs to fill, which only happens with the movement of driving.
The matter was referred to Germany. I collected my latest purchase today (991 GTS ??) and was told that Porsche had "closed the ticket". I think that means they're not going to do anything further. No explanation, no acknowledgment of the problem, no solution proposed.
Has anyone else noticed this? What alerted me initially was the large amount of water needed to top up the bottle even if it had not been used. I love the car but I don't like the problem being ignored.
You just rang a bell.I have the V6 Petrol 3.5 which i bought last year .
I have only done 1000 miles in it and have not taken it out in bad weather
so have not used the wash wipe.However i have refilled the resevoir twice and on
both occasion it took almost a gallon .
I will look for tell tale drips on the floor .
By the way ASDA are doing TWO GALLONS for £4.00 at the moment
I have a 2015 Diesel S and don't have this problem. Mine is used for Country sports and is out in all weathers (has been very wet) so wipers and washers used a lot. Great car with a lovely exhaust note and handles rough stuff and towing very well but tyres limiting factor in mud
Just an update - PGB called me yesterday to say the matter was back with the factory marked as 'urgent'. I sensed there is a recognition of a wider problem...the only way to be sure with your own car is to fill to the filler neck, drive a few miles without using the washers, then refill. We've done it several times now to establish that it's not just air trapped in the filler neck which clears when driving - the visible leaking rather validates that too.
I have had a clonking on my front drive shafts on the V8 for a number of
years.we cant find out what is wrong with it if anything ?
