Do you guys think it's a good idea to put 20mm spacers on the front? I guess I will need a longer stud?
It's just that I found a 7.5j ET35 Rims that I want to push out an extra centimetre and a bit (otherwise a 6mm spacer would suffice, and apparently can still use the stock studs).
This is for a square dash 944, ET23 offset I believe.
Also out of topic question: Where can I buy insulation pads for the bonnet? Or any good DIY buy the material and cut-yourself guides?
