23mm Master cylinder upgrade advice please
- Thread starter Mike58
What are the piston diameters on a monoblock caliper? Compared with a 930 caliper? That will give you the answer.
The actual swapping out process is fairly simple. The master cylinder is right in front of the brake pedal. My mechanic did mine and I recall being relatively painless on the wallet. You can use a 23mm Mercedes master cylinder at somewhat less cost than the Porsche 930 one. The new cylinder should be bench bled to get rid of air bubbles before installation.
Richard
