245 tyres
- Thread starter skendrick
I believe Rick has slapped a pair of 245's on the front of WUF. They look the parts but I don't know what they would behave like on the limit.
Personally I am a bit dubious about fitting the wrong tyres as it would worry me that the bead wasn't seating correctly. Lets be honest, if it didn't work you would only find out when the tyre came off the rim during significant cornering pressure. Not good me thinks.
That said I have gone up from 205's to 215's.
Diver944
250 Turbos should have 7.5 fronts and 9 rears with 225 front and 245 rear
S2 D90s are 7 front and 8 rear with 205 front and 225 rear
I have 245 track slicks on an 8" D90 wheel and it behaves fine in extreme circumstances [] but the slicks have a VERY stiff sidewall so I would check the width tolerance that the tyre manufacter specifies for its 245 tyres
