2D Stereo
- Thread starter g59tester
There is a metal bar between the two sections so you can only fit a double DIN with and angle grinder and some fab work. Then you’re limited as to what you can fit as it must be very shallow due to the angle and depth at the bottom.
You can make it work if you try though, it’s non-reversible though!
