Hi everyone ,1st Thank you for a great week end in and around Malton .
We had a good run back as far as Patley Bridge then clouds of blue smoke .
traced it to the engine side of the gear box .
Just had box oil changed and put in the swepco oil.
Is there any info on the effect of this oil on the oil seals ?
as far a I can see there is only one place that close to the engine that it can come from
and that is the main input shaft but oill appears to be coming from above the bell housing and running down and dripping off
the clutch operating lever /spring .
Any info appreciated before dropping the whole lot out .
