3.2 mods
- Thread starter Guest
2. Straight through exhaust, without silencers.
I assume that this will be for racing only ?
They tell me that the normal exhaust (which I had replaced, of course) is quite good for the road - back pressure et all.
I have a sort of induction kit on mine (K&N etc.), but this was because the normal one would not still fit.
Not helping much, am I ?
The installation is just like the one in the current 911 and Porsche world (fitted by the same person), apart from the air-con (which meant a different drive belt).
In the picture above, what is that little filter thing on the right?
I hadn' t noticed that before - I assume it is a breather filter. The oil tank vent (to vent excess oil fumes) would be into the intake somewhere, upstream of the throttle body; the oil tank is on the right, below the filter.
Mind you, I could be entirely wrong (as if !)
Mine hasn' t got one.
I am an atheist, and ' er indoors is Buddhist, but we like visting different religion' s ' temples' .
I know this is off-subject, but I am in inquisitive soul (OK, nosy !). So, back to porkers.
ClubSport 911
I' m being slightly picky, but any structure between the air inlet and the combustion chamber is " seen" by the engine as part of the induction system, and this includes that biscuit tin we call the " airbox"
Theory has it that some engines like to breath from still air - relying on the space of an airbox (pre- or post air filter) as part of a resonant chamber to change the frequency of the port pulsations to help with induction.
This is most certainly the case with road cars where in order to drive, you need a wide engine range and smooth torque delivery. (Varioram is a good example, but so is variable inlet on any Vauxhall 2.5 V6)
A small inlet dimension, and no plennum / airbox promotes good breathing at high speed only at wide open throttle and high engine revs.
So...in summary Airbox' s might have a function after all, and sometimes it' s not all bad. I learnt all of this as part of working and was involved with 4 very very well known car manufacturers performing hundreds of hours of dyno testing to optimise the size / shape / nature of the inlet. I was there to do other stuff on the sites (sell would you believe it) but I just couldn' t resist the acccess to engineering at this level.
But...when you' re racing, have forced induction (super / turbo-supercharge) then all bets are off - the rules are very different.
At risk of contradicting John
What the hell, do it anyway !
You are quite correct about the inlet side, and I can only speak from the forced induction side.
I will go away now.
Simon Davidson
The picture of the car fitted with the twin cones is one of my kits. I havent power tested one of these and there is a chain of thought that says bottom end torque benefits from an airbox but the induction kits sound great and seem to increase performance at the top end. I made the kit for my car initially as it looks nice and sounds nice and I felt as though i could accelerate faster at the top end and after all low end torque is not something i care much about although I cant feel any difference at low revs anyway, i guess if you want to pull a caravan its worth thinking about torque.
the picture shows one of our stainless steel cones, I can supply the same kit with a K&N oiled cotton cone filter if you prefer. The stainless is rated for engines to 500BHP and is the most common version used on Supra twin turbos and escort cosworths, whereas the equivalent K&N is rated up to 340BHP. so both are fine for our cars.
You can see these and come for a chat on my stand at Eynsham hall if you want to check it out for yourself.
Cheers Simon
www.essentialstyling.com
