andrew symms
my exhaust is starting to blow in several places, can anyone offer advise on stainless systems and where is best to get them from??
Andrew
Andrew
ORIGINAL: Richard Bernau
Phil,
Does your mechanic have all the pieces to backdate? I have been poking around trying to collect all the pieces and have found it quite difficult. I do however have a list of everything you need. More recently I just asked JAZ if they had them and sure enough they have "loads of old tin" and ducts so problem solved.
Looking forward to hearing how your SSIs work out. What muffler will you use?
RB
ORIGINAL: CTJM
Hi Richard
What do you think of the sports outlet pipe being offered by some companies which connects directly to the presilencer and eliminates the rear silencer box completely? surely the noise from this setup must be bordering on illegal? Also going off your "larger bore,less mid range" advice would this further aggravate the situation?
Questions,questions you must think but this area as I'm sure you'll agree is the proverbial "minefield".
Ian
