3.2 Speedo light
- Thread starter Guest
Bulb change is very straightforward - pull out the speedo (you may need to push from the back) and remove the bulbholders (usually quite stiff) to replace the bulbs.
You will probably find, however, that it makes almost no dfference! - I did mine and it didn't seem to do anything. There's been some interesting discussions on using 4w bulbs or LED's on the US websites (Pelican for example) but nothing definitive has come out yet.
Roy
I know that you can get UV LEDs (which, in fact, shine white with a hint of blue), and they are advertised as being for car intruments - I have yet to try them; maybe I will go and do that.
plhorner
Moderator
It is the round red fittings, from what I remember they are quite tight. They are held in by the earth contact which is basically a metal cup that springs into the holder / instrument body.
Have you bought new bulbs yet? They are quite strange little items that I'd not seen before. However I managed to buy a handfull from our local auto electrical specialists for a couple of quid. But as mentioned in a previous post, the result was less than satisfactory.
Regards,
Whisch are the bulb holders though? I tried pulling the little round red fittings but they spring back in - is it the spade conectors at the top?
Glad to see someone made the same mistake as me, and I've done it a few times already. The little round red fittings are attached to a metal tube - it is this tube that pulls out, leaving the connectors in place, and presenting you with a spring loaded bulb (hence the springing back business) at the front of them. This then twists out like normal car bulbs.
(I hope !)
Evil J Guano
No idea if it works on more modern cars though...
