Mike.Gamble
I've been offered a '03 S with a few issues.
Basically, she's been neglected a little (and some may say, stay away!) however the garage who are trying to sort her out for the owner (not Porsche specialists) say that apart from the fault which I'll go into in a moment, the car seems quite good.
A few months ago the engine management light came on and the owner kept driving and never bothered having it looked at.
A few weeks later whilst driving the car, it cut out completely, just died and rolled to a stop. No bangs, noises, pools of fluids, just stopped working.
My local garage are a recovery agent and as the owner is fairly local, they recovered it for him. Once back at his garage, the owner asked them to fix the fault. The garage reluctantly agreed and discovered a blown fuse. The fuse was replaced and it blew again.
[/URL] [/IMG]
The offending fuse is the 25 amp one, on the 4th row of fuses from the bottom on the left hand side.
My local garage couldn't find the root of the problem so it was then taken to OPC to be looked at. As is often the way, the car didn't display any faults while with them and although then ran it up several times, they could find nothing wrong.
After refusing to allow him to have the car back unless it either was trailered back or, had two new rear tyres as they were showing cord (I told you she was neglected!) he collected the car with her new rear tyres and started to drive it back. As could be almost predicted, it got halfway home before completely cutting out again!
The owner once again called the local garage to collect him and against the garages suggestion of returning the car to Porsche in it's non-running state for diagnosis, the owner decided to have it brought back to the garage for them to look at it!
The garage are not to keen to dig deeper as they're of the opinion if Porsche can't find it, what chance to they?
Once again, sometimes after the fuse is replaced the car will run fine for a couple of days but then it will suddenly go and then blow a succession of fuses. The only thing the garage have noticed is that there does seem to be a link with when the fuses blow and when the car is 'jolted' ie going over a speed-bump, pot-hole etc.
My thoughts are, the ignition? For something to happen where the car just stops, 'as if the ignition has been turned off' is that the ignition has turned off. Faulty barrel, broken wire etc?
Any thoughts or similar experiences?
