mcgc0
He's asked for my help and seeking advice and comment on his recent turbo problem. Hoping someone can suggest options...
"I am having more problems with the Turbo 3.6 . After carrying out a major service I noticed that the turbo boost was kicking in a bit later, i.e. at a higher rpm, and power seemed less. Shortly after, a loud high pitched noise similar to a siren started coming out from the back. At this point I noticed that the turbo boost gauge was showing no boost at all.
I suspected that the turbo is the problem and now after taking it to the garage and opening the top of the turbo it appears that the blade inside has worn out and the metal residue which is like fine powder has found its way into the throttle body.
I am told now that the turbocharger has to be completely replaced although in some places, like the US, it is possible to repair it. I am wondering if you can check on this issue with your and if I have to buy a new turbo, the price."
If more info is needed I can go back and ask him..
Thanks All.
Marcus
