30k change your timing belt "or"
- Thread starter rob944s
carlmthompson
They were given a clean bill of health two years ago when I had them checked.
Saying that, I'm going to get them done this year inc. the rollers etc. as the consensus seems to be that I'm pushing my luck!
Diver944
Why risk a bill in the thousands or a new engine [
sawood12
I personally will look to replace between 30 and 35k miles wherever a major service falls between that mileage. I certainly wouldn't go more than 4 yrs - again i'd probably replace between 3.5 and 4yrs and i'd always replace the balance shaft belt.
Diver944
sawood12
What is the consensous on what exactly to get replaced? Both belts a given, but what about rollers/tensioner? Some of the menu based servicing prices I've seen (RPM Porsche for example) just include belts, no rollers.
Can someone advise what I should sensibly get done, and how much to expect from a decent indie?
Also I read about the camshaft timing chain needing inspecting. Car has done 94k. Do I need to do anything on that?
Cheers,
Ian
pauljmcnulty
RPM did my belts, rollers, seals. Water pump was fine.
All in about £700 including the vat, IIRC.
Diver944
ORIGINAL: ians
both belts were changed 32k miles and 9 years ago, so sounds like they are due.
If it really has been 9 years then I would also do the rollers and tensioners unless your Indy is positive that they will last until the next change.
If you have an S or S2 then the consensus is to get the camchain and slipper changed every 50k miles which also gives the mechanic a good chance to inspect the cams for worn sprockets or any early signs of the case hardening failing
pauljmcnulty
ORIGINAL: scz
Absolutely Paul, just done all mine including rollers and a new hose...your price is spot on, I did water pump at the same time for another £400. In for a penny...[8|]
Just out of interest, RPM would have done the water pump at the same time for just the cost of the pump - about £150 IIRC. Whilst the car is in bits it's a simple job to change the pump as well so shouldn't add to the labour cost.
pauljmcnulty
ORIGINAL: ians
any idea what the rollers /tensioner should add to the cost? I assume its a trivial job to change them when the car is stripped down for the belt change.
Ian
See other thread!
Suffice to say that it's cheaper to get the whole lot done than to have the belt changes, and then 3000 miles later have it changed again because the seals are leaking! [
