6 point harness and fire extinguisher
rs phil
have 4 points in my car with all eye bolts screwed to tunnel rear shelf etc, was goin to fit crotch strap 2 points,is there a bar i can put between seat mounting point,or do i have to drill the floor and fit plates with nut welded to it,also i have 1 eye bolt on each side on rear shelf which was fitted fo 3 point harness, is it ok to put 2 catchs on each of these rather than drill more holes as i have 4 point so 2 to each eye bolt,have fitted them this way before very tight to get onto eye bolt,just wondering is it dangerous?also any one fitted fire extinguisher like gt3 one to their rs,again do you have to drill the floor to fit this
[FONT=verdana,geneva"]
You'll need the second mounting on the parcel shelf if you are going to fit a 4 point harness otherwise the belts will be coming over your shoulders at the wrong angle in the event of putting them to the test. Some of the RS have the necessary mounting points on the shelf and some don't (mine doesn't)
Don't know if you have looked under the car yet ? but you may find the attachment points for the crutch straps are already there.
had a look under passenger seat a while back and spotted the 2 pressed in threads,what about driver side,ecu is in the way,do you just take it out screw in eye bolts clip on crotch strap and the re fit ecu,or do you have to move ecu?thanks
I think the N-GT had the ecu moved to enable the crutch straps to be mounted. IIRC, it was repositioned to the rear "seat" area. I'm sure Des will be along soon to confirm.
yea i noticed that on n-gt models,have seen loads of normal rs with 6 point just wonder how..easier to ask than drill holes in the floor[:mad:]
ORIGINAL: Stewart H
Correct......but also makes unit more accessible for changing over.
In the Cup races, all of the units were removed from the cars and then dished out randomly to ensure no tampering........
You can either move the ecu further down on it's plate or as you say move the ecu to the "cup" configuration. Some cars may or may not already have the fixing holes. Mine did'nt but i made some anyway. The plate for fixing the ecu to the cup car fixing is a porsche part number. But it's a very simple stamping that could easily be made diy
Hi rs phil - if you can hold off drilling holes for a few days , I'll go have a look at how my crutch strap is attached (!)......from memory there's a fitting that bolts into the seat mounting rails and no drilling or welding needed, assume thats OK for the load as it was a race team (Tech9) that did it for me [:)]
yeah - mounted on a steel plate held down by two bolts which go into a couple of threaded holes on one of the ribs on the floorpan. steel plate then has the two mount brackets for the extinguishers. std porsche fit
phil
no idea mate - not able to get to car either in near future
can have a butchers in couple of weeks time if you remind me
matt
I have two Clubsport extinguishers and the plate so can probably find the numbers --- will have to delve into the barn.
But, they are very heavy and are probably useless after 15 years.
Are you buying for show or go ?
OK, these would appear not to have a Porsche part number.
Manufacturer --- Kingeler ?
I'll post a couple of pics (now I can !) but if you want the files high res --- you may be able to decipher the address. Maybe a Google search on Kingler would work ?
As you will see, one of my extinguishers has been used ? !, the other appears to be OK.
But I wll not be relying on either -- I'll fit a modern alternative.
thanks for your time and effort,yea you are probably right one modern exthinguisher would be better ..cheers
