I run a 3.0 turbo and as a regular user of derestricted Autobahns I noticed early that a tall top gear was needed. In fact I barely take the car out anymore these days, unless I have a mate to visit over in Germany.
The easier way to build a tall ratio 968 gearbox is to source gearsets from some FWD Audi/VW diesel gearboxes, as the 968 gearbox belongs to the same family of the 01E gearbox series. I will leave you the fun of hours browsing through ETKA (VAG/Audi's PET equivalent) to see what can be made to work.
The bottom line is that only gearsets 3/4/5/6 can be swapped, as 1st and 2nd gear are part of the main & secondary shafts, and we can't use the ring & pinion from the Audi gearbox as the differential is larger (or smaller, can't remember which was which when I measured them). The cherry on the cake is that there are several 'boxes to choose from, which will offer different gearings. I chose one that has given about the same first 5 gears of the 944T 'box, but with a super tall 6th on top. Makes for cruising at 120mph at 4k rpm, which is über cool when you have the kind power to properly propel the thing.
I keep hearing about fragile synchro rings on these gearboxes, and some Audi folks in the US seem to offer carbon-layered upgrades, but I have no idea if it's worth the cost over new standard synchro rings, at least for people like me who run their car only on the road and change gears like if they were walking on eggs after doing such a pricey investment (talking roughly €5k after all is done, including sourcing a used Audi gearbox on ebay for €500 with thankfully undamaged gearsets, a shiny new OS Giken LSD, rebuilding half shafts with unmarked cages, plus all the parts needed to fit this all to a 944).
