hi Gary I think you may have connected something incorrectly when dealing with the rear lights. Check the fuse chart on the fuse box, or in the hand book if this is still with the car. Failing that ,contact Nick Moss or Roger Bray, they both advertise in PP good luck Have fun Paul Kelley
71 2.2T FUSES KEEP BLOWING (UP DATED 12 JULY)
- Thread starter paul kelley
The fuse that does the indicators and the handbrake warning keeps blowing......the only thing i can think of (just thought of this in the shower), is that today i replaced the rear lenses...and while is was there is took out the light housing and there was a brown circular spade (thought is was the earth for the housing) so i screwed this to the housing when i put the housing back.....is this right or not?....its the only thing i can think of thats possibly changed ???
Also.....the fuse that does the luggage lights, clock and interior lights also keeps blowing (seperate from above).....the clock does not work neither does the interior lights but the luggage compartment lights do, but something keeps blowing the fuse.....any ideas ??
I HATE ELECTRICS !!!!!!
ANY HELP WILL BE GREATLY APPRECIATED
Alex Postan
On ze relay zat delivers the vull 10,000 volts fur der electrische chair, nicht wahr?ORIGINAL: 66ghia but where the hell does the spade belong !?!?!?!?
craig2105
Disconnect and ignore. My kinda maintenance [ORIGINAL: 66ghia i took the spade off the housing and hey presto.......we are all working again......great news.....but where the hell does the spade belong !?!?!?!? Cross that bridge if i come to it
Alex Postan
That's easy to cure; don't brake. It is good to remember the economy driver's maxim "The accelerator pedal uses petrol but the brake pedal wastes it"
early 911
Moderator
I would recommend a trip to an auto electrician . . . . and take a wiring diagram with you (this link doesn't appear to work on my computer, but it might on yours [link=http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1971_Part-1.jpg]http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_1971_Part-1.jpg[/link] ) Phil
My saga update.........the brake fuse situation is now sorted, it turned out to be the bulb was not sitting snuggly in it's holder. It does now and no fuse has blown. The original post is still a problem. The luggage lights work but the fuse occasionally keeps blowing....the interior lights do not work neither does the clock (all run off the same fuse). If the interior lights and clock does not work......was is causing the luggage lights to keep blowing?. I really don't want to get a electron involved as I'm on a mission and want to sort this myself !!
Im refusing to spend money on a electrician !!!!..........brake light drama is sorted.....reversing lights - need to check switch....clock - no idea !!.........interior lights - ive taken the four door switches out (two have blue wires connected and one has brown, the other one (assume should be brown also) is not connected, how the hell do i find the wire in that space ?????????????????????????
Alex Postan
In the good old days of not so long ago, the rough end of the motor trade would have used these "difficuties" as an excuse to torch it.[
