Morning all,
I'm hoping that somebody might have the answer to a problem with my windscreen washer which is causing me some grief.
Problem:- When operating the windscreen wash, the wipers work but the pump only works intermittently. It used to work ~50% of the time, now more like ~5% or less.
What I've done so far:-
New pump
New spade connectors on the lead wires
Checked earth wire - OK
Checked switch - OK
Checked getting 12V at the pump when switch pulled - OK
Here's the really weird thing though, when I attach a multi meter to the pump feed/earth wires, I ALWAYS get 12V. I've stood and repeatedly pulled the wash lever about 50 times over and I always get 12V, yet when I plug the pump back in I rarely get any action.
I have also checked the earth as best I can, when I plug a multi meter into the earth wire and touch the other lead to the inlet manifold, I get 0 Ohms resistance, hence making me think the earth is OK.
-UPDATE- Made up a new earth wire with spade connector, plugged into the pump and fixed the other end to the manifold. Still not fixed, hence problem not with the earth wire.
I have checked the new motor to make sure it's not faulty - when I plug it into another car it works perfectly 100% of the time.
As far as I am aware the washer pump is not connected via any relays or even fuses (According to the fuse/relay layout diagram in the manual).
I am convinced that this is some problem with poor connection somewhere, but the wires for the pump go straight back into the loom and I have no idea where they come out and where they are grounded to.
Is there something I'm missing? Is there a relay or fuse involved somewhere I don't know about?
Any thoughts at all on the matter would be deeply appreciated!
Best,
George
New pump
Checked switch - OK
Best,
George
