84 Lux - headlamp washer pump?
Hi
Looked on Clarks as well as the American Haynes book and can't find where the headlamp pump is situated. Obviously its around the washer liquid tank, but not sure where?
Also, is it a straight forward job? Its a given its going to be fiddly!
BB
The pump is further down in the water tank on the front side of the tank, It might be pushed into the tank on some O-rings it is a long time since I took one out.
What is wrong with it?
Baz
It's straightforward once you've removed the washer bottle. Few different ways to do that, I took off the undertray and came at it from below, others have tried to get to it by removing the inner wheel arch.
Once you've access, undo some pipework, unclip the electrics and it just pulls out.
