MrBlueSky
Hi All,
Not seeking help this time, I've been having issues with my S2 unexpectedly losing power for 6-8 months. I had the AFM cleaned up which improved things but occasionally she'd revert back to her bad habits and not have enough power to pull the skin off the proverbial rice pudding! It started to happen more frequently of late and it seemed to be exacerbated by cold temps and I knew it wasn't the DME relay, having recently replaced that too. Long story short, I found an article that discussed similar symptoms that were cured by the replacement of the DME temp sensor, the throttle position sensor and the idle stabilisation sensor. I replaced all but the latter and, touch wood, my 944 has never run better.
Hope that helps?
Hope that helps?
