Hi, Got a '72 911E Sportomatic.
It's been sitting for a few months waiting for an oil tank.
Just fitted it but when I tried to start it the throttle linkages were sticking open. Freed them out now and they seem fine.
Problem is the clutch doesn't seem to want to engage. If you put it in neutral it seems to be fine. Touch the gear stick and the clutch operates and the clutch is depressed.
Put it into gear and let go of the stick and it makes a sound like the clutch is being released, but it stops driving the drive plate. I haven't seen if it is the clutch or the torque converter that is not driving yet.
Is there any special procedure for bleeding the torque converter after changing the oil tank / changing the oil.
Oil level and oil pressure is fine.
Thanks for any help or advice.
Paul.
Paul.
