911sc 1983
- Thread starter Malc458
To get to the switch itself you then remove the fresh air blower and plenum from inside the luggage compartment.
It recommends disconnecting the battery -ve first, and labelling the two wires on the switch before disconnecting them.
And then, in the "Haynes Manual Best Practice" it says (and I quote) ... installation is the reverse of removal.
Thanks that's very helpful, i removed the collar using a fencing staple and a pair of pliers - easy. do you know if its possible to buy a new switch?Old and Slow said:According to the Bentley Manual for the 911SC, you unscrew the knob in a anti-clockwise direction and then use a 2-pin spanner wrench to remove the retaining collar holding the switch in.
