Hi I have just bought a 79 SC which has run wonderfully for the last 4k miles - then some nasty failures that i'm now grappling with any help appreciated:-
1. Electronic speedo not working (i suspect the sensor as per Haynes manual diagnostic - is this a common failure?)
2. Front fogs not working (rears working & bulbs okay) i think likely to be the 2 position switch - if so how on earth do i get at it ? reaching under the dash there appears to be a solid panle in the way!
3. Headlights working on dipped beam only & the headlight switch on the LH stalk is totally ineffectual could this be the switch itself within the steering column?
No fuses appear to be blown as i've checked all with a DMM - Is it likely that a relay might be causing these problems or am i just unlucky with a systems failure?
thanks in advance
Tim
thanks in advance
Tim
