911sc Fuch alloys
- Thread starter Malc458
Warm/hot water and Fairy liquid works well, depending on how much and how long the brake dust has been on will require more or less elbow grease.
Polishing with Autosol or the likes is likely to polish through the anodization of the wheel.
One tip is to coat the wheels with petroleum jelly (vaseline). This will protect the anodizing and if your wheels have become a little hazy (if for example some acidic/strong alloy cleaner has been used) it may even bring them back to original finish.
Am sure Autoglym do one that specifically includes anodised.
Then, apparently according to porsche factory back in the day, apply petroleum jelly for half an hour then wipe off with dry cloth. Apparently brings them "back" and a thin film helps protect them.
Not got round to using the PJ on mine just yet but do have a jar for it
fxm911 said:Be gentle with your Fuchs especially if they are factory finished, you do not want to "attack" the anodising.
Hi Thanks for that. The alloys are very original and in good condition externally; i shall definitely use vaseline here. it is the inside of the wheel which needs brake dust removed and i was going to use white vinegar / fairly liquid, Any views on this? Thanks
If your wheels (anodising) are in good condition then I would not use anything on them that could mark/damage it.
NeilH said:Apparently you have to go careful with anodised rims. Only use mild wheel cleaner!
[NeilH/quote]
just polished wheels (paint and bare alloy parts) with PJ and they look really good.
