After trying every trick in the book to cure the oil leaks on my 1978 Porsche 911SC I have finally come to the conclusion that I need to take the engine out and do a rebuild to cure this issue. I have owned my 1978 sport SC for 27 years. I purchased it with 100k miles on it and proceeded to add another 135K miles. For most of those miles it has run really well.
If anyone is thinking of taking their engine out then a hydraulic lifting table purchased from Machine Mart, as shown below, is a very handy device to have. Just undo the 4 main bolts on the engine & gearbox, disconnect the pipes and electrical connectors, oil pipes then drive shafts. Then a few handy pieces of wood to protect the engine and it can be lowered from its compartment.
I take the heat exchangers and rear exhaust box off before putting it on the lifting table. This means I do not have any vertical bolts to deal with. The engine still in the SC was looking very messy. The oil leaks seem to mainly be coming from cylinders 3 and 6. Let’s see if I was correct when the engine comes out.
Next part to follow shortly. Rich
