924S/944 belts
dgw
Can anyone advise on how to retension the alternator/ac belt. Theres lots of squealing coming from that area of the engine and it may be that the belt is to slack. Any additional/
altenative info would be appreciated. Thanks.
Remove the undertray & from under the car you'll see a pair of large threaded belt tensioners with lock nuts. IIRC you need a pair of 17mm spanners. Undo the locking nut, rotate the threaded outer section to lenthen or shorted the tensioner. Check the manual for how to tell when it's the right tension, IIRC you get 1cm deflection on the longest distance between the three pulleys at the right tension, but you could just tighten the belt a bit, see if it squeals etc.
IME if a belt is squealing it could probably do with replacing anyway (unless it's just been replaced & incorrectly tensioned).
Riverside
Thanks for that. It all worked out quite well.
I don't have a 944 manual so I estimated
what the tension should be.
Many thanks
