924S Auto MPG
- Thread starter russ_d
I have a 2.7 944 automatic which gives a consumption of between 20 and 27 miles per gallon depending on how it's driven and the type of roads.
The automatic box only seems to change from second to top at about 45 so around town and in 40 limits you are only in first and second.
I would assume a 2.5 924S automatic has similar change points.
Mike
White 2.7 944 automatic
Seems that we are in a similar location - I'm on the A21 near Lamberhurst. Do you have any good local mechanics and where did you get your MOT done as I will need one in a couple of months.
I use Bosch super sparking plugs and have fitted new Beru leads and am using Redex injection cleaner which seems to have helped improve the fuel consumption.
Mike
I'm on the A27 in Sussex mainly but the car lives between here and the A2 in Kent.
I use these these people GM Autocare as my friend is a mech there and they have a reasonable reputation. They were also happy to replace the seal on the oil cooler which a lot of local garages turned their noses up at!
MOT was £55 iirc
Going to order some plugs, leads, air filter etc and see how she is then. Think the lack of use does not help either.
Russ
Fred Hindle
Cheers,
Northern924
Around the doors it was more like 28/30, at present prices you should be get 120 miles for your £20 ( that's based on 18 litres costing £20 which is 113p per litre)
