Hi All
After recently joining the 924 fold it is time to get some work done on the car to get it back to how it was meant to be.........
The car in question is a 1986 924S and as well as the usual safety first issue of getting the belts done it has the all too common issue of Diff Whine. Whilst the belts are not a problem it would appear that the diff problem may be a bit more expensive to repair and wondered if you have any advice on how to approach it. The problem can be described as a whine that is there on acceleration and trailing throttle but disappears when there is no load on the diff (when feathering the throttle). From this I believe it to be the pinion bearing.........
Is it economical to get the gearbox repaired (any idea of cost) or am I better buying a replacement 'box? If it is the latter do you have any suggestions of a reliable source of a replacement 'box so that I can guarantee I won't be replacing with a item that is worse?
One last thing - is there any chance of the diff giving way completely (car done 96k miles) and if so what is the damage likely to be?
Any help or advice would be grately appreciated.
Andy
Andy
